Pomoc RSS downloader ratio problem
xBenny
25 Październik 2022
I encountered a problem with the ratio in the case that I add torrents according to the rule via RSS and I have the default ratio set in the main settings.
Example: I have the default ratio for all torrents in the main settings set to 2. Via RSS, I set the automatic addition of a torrent without a ratio, or with a ratio of 10. The torrent will start downloading automatically, but the ratio will not be set to the value from the RSS downloader, but the same set to value 2, which is in the main setting
so I gave it a try and it happens that if I set No ratio, the ratio from the main setting is set. If I set any other, the ratio will be set according to the filter. Therefore, it is not possible to set No ratio through the RSS downloader, if some default is set in the main settings.
  1. download
  2. rss
