Pomoc rTorrent Pro will not start after firmware update
DickyDck
12 Sierpień 2018
USA
Firmware version: 4.3.4.0675 Build 20180810
Model name: QNAP TS-1277
Hello, I upgraded my firmware today and now I cannot get the GUI to start up. When I first bought this last week I couldn't get it to work, then I bought a new router and for some reason it started working, then I upgraded firmware and it stopped again. I'm getting an error stating...
"mynasname.myqnapcloud.com took too long to respond."
in the logs this pops up every now and again...
(warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
I have already tried uninstalling and reinstalling it with no luck.
Thanks! I finally figured it out. Seems UPNP on my new router is moody and it sometimes auto-sets the port forward, and it also removes UPNP mappings when not in use, and sometimes doesn't start it back up. I have gotten it back up and working. I will need to do the same with the FloodUI if I ever want to use that, but I like the Advanced UI. You helped me out on the other QNAP forums about the VPN, thanks for that! Do you happen to know of a way to get a VPN to only work for one interface on the QNAP? the proprietary QVPN funnels ALL traffic and ALL network interfaces it seems. I would like some way to have one dedicated network interface for rTorrent Pro and have it protected by a VPN, (PIA Vypr, AIR, etc) and normal traffic run through another.
I think its gonna be better for you to use some router like Mikrotik and make traffic travel on specified interface through VPN. After that you can bind rtorrent-Pro specified interface to be working on this VPN.
