altaroinj
31 Marzec 2018
16
Hello all,
first of all, and I may repeat myself, thanks again for rtorrent. It's one of the few apps I did not hesitate to pay for, and I don't regret it.
Then, I would like to suggest Silas Mariusz Silas Mariusz 2 things to improve.
1. If it's not possible to automatically backup main configuration page at each stop/start of the app for example, do you think we could have a way to export/import it ?
Because, each time the app is updated, we need to reconfigure everything as the configuration is reset to default.
2. I use the feature that allows me to execute script on finished downloads. I use it mainly for sending notification on my phone using pushover service (I can share my script if someone wants to do the same).
But, rtorrent handles a lot of event types and some I would like to use too.
So I renamed "_event.download.finished" into "_event.download", and modified it in order to be able to do the same, but for all event types.
You can find it attached to the thread (with sh extension because otherwise it was not accepted).
Just to explain, I only set the 3 first arguments as mandatory, because for inserted* events there is no path yet for the downloaded file.
And I splitted log files (one by event type) as differrent event types can occur at the same time and logs of executed scripts would be mixed between each other if I hadn't.
I kept the main log file for debug purpose (if the DEBUG variable is set to 1).
So with this new script, I modified "rtorrent/etc/rtorrent.conf" in order to comment the line :
# method.set_key = event.download.finished,bash_handlers2,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download.finished\"),$d.hash=,$d.name=,$d.base_path=,$d.custom1="
And I added these lines instead :
method.set_key = event.download.closed,closed_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),closed,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.erased,erased_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),erased,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.finished,finished_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),finished,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.hash_done,hash_done_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),hash_done,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.hash_queued,hash_queued_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),hash_queued,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.hash_removed,hash_removed_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),hash_removed,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.inserted,inserted_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),inserted,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.inserted_new,inserted_new_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),inserted_new,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.inserted_session,inserted_session_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),inserted_session,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.opened,opened_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),opened,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.paused,paused_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),paused,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
method.set_key = event.download.resumed,resumed_bash_handler,"execute.nothrow.bg=(cat,(cfg.scripts),\"_event.download\"),resumed,$d.hash=,$d.name=,$d.base_path=,$d.custom1="
Everything worked as expected.
My question now is, do you think Silas Mariusz Silas Mariusz that these enhancements could be part of one of your further release (in order to avoid resetup everything after each update) ?
Thanks in advance for your response.
Firmware version: 4.4.2.1270 Build 20200410
Model name: QNAP TS-253Pro
  • _event.download.sh
Rozwiązanie
Until this thing is not solved by QNAP we cannot implement it. Stay tuned!
In the meantime, could you tell me where the configuration is located in order to do a backup ?
my idea is to execute all these events from the scripts in subdirs like:
Rdownload\scripts\event.download.closed\_execute.script
I didn't really understand what you mean. Do you mean that you will duplicate _event.download script for each event in a subfloder, and that script will handle all scripts in its subfolder ?
Or do you mean, you will have a single script _event.download at root scripts folder, that will execute all scripts located in subfolders according to event type that triggered it ?
I must confess, I prefer the 2nd solution, and in...
Thanks Silas Mariusz Silas Mariusz
I installed the last version.
First, it didn’t changed the rtorrent.conf file.
So I stopped the app and deleted it.
At restart, rtorrent.conf.default was copied into rtorrent.conf and everything worked.
Finally, maybe this procedure would have worked with the previous package.
The fact that rtorrent.conf file is not overridden during application update, is it part of the new process that maintains overall configuration ?
Regards.
Yes.
You can simply upgrade app and then click:
to apply new changes.
If you dont, all new features will not be implemented unless you select them in config.
ffs! open NEW topic !
With this new version, is there a way I can get it to 'Stop and Clear' and then 30 mins later 'Remove and delete data'?
I like your idea with many types events. Honestly no one asked for this before, but my idea is to execute all these events from the scripts in subdirs like:
Rdownload\scripts\event.download.erased\_execute.script
Rdownload\scripts\event.download.finished\_execute.script
Rdownload\scripts\event.download.resumed
So if you use same script for all events you will have to put it in each event directory. Is this okay?
I appreciate for your feedback.
Thank you!
Silas Mariusz Silas Mariusz, I am referring to your own comments in this thread where you showed support for scripts that execute after a (download) event!
altaroinj altaroinj
I observed that triggering hash_done, hash_queued, hash_removed, inserted, inserted_session events makes no sense. And these events are executed when Rtorrent starts. Imagine you have 10k seeding torrents. In future release we have to remove these events to improve rtorrent start speed.
  1. export rtorrent
  2. rtorrent.conf
