KrzyCho.corp
Zainstalowałem wersję stable, i co dalej? Jak zainstalować dodatki (nie ma takiej opcji)
i co dalej?
jerry1333 jerry1333 - dawaj szklaną kulę ! wrózenie potrzebne !
dalej w kontenerach ? i co dalej ?
ja mam tak
docker-compose.yml:
YAML:
version: "2.1"
services:
  piper:
    image: lscr.io/linuxserver/piper:latest # https://hub.docker.com/r/linuxserver/piper
    container_name: piper
    environment:
      - PUID=${apps_puid}
      - PGID=${apps_guid}
      - TZ=${apps_timezone}
      - PIPER_VOICE=en_US-lessac-medium
      - PIPER_LENGTH=1.0 #optional
      - PIPER_NOISE=0.667 #optional
      - PIPER_NOISEW=0.333 #optional
      - PIPER_SPEAKER=0 #optional
      - PIPER_PROCS=1 #optional
    volumes:
      - ./config/piper:/config
    ports:
      - 10200:10200
    restart: ${apps_restartpolicy}
  faster-whisper:
    image: lscr.io/linuxserver/faster-whisper:latest # https://github.com/linuxserver/docker-faster-whisper
    container_name: faster-whisper
    environment:
      - PUID=${apps_puid}
      - PGID=${apps_guid}
      - WHISPER_MODEL=tiny-int8
      - WHISPER_BEAM=1 #optional
      - WHISPER_LANG=en #optional
    volumes:
      - ./config/whisper:/config
    ports:
      - 10300:10300
  openwakeword:
    container_name: openwakeword
    image: rhasspy/wyoming-openwakeword # https://github.com/rhasspy/wyoming-openwakeword
    user: ${apps_puid}:${apps_guid}
    volumes:
      - ./config/wakeword:/data
      - ./config/wakeword:/custom
    environment:
    ports:
      - 10400:10400
    command: --preload-model 'ok_nabu' --custom-model-dir /custom
  home-assistant:
        container_name: homeassistant2
        cpus: 2
        mem_limit: 2048m
        privileged: true
        restart: unless-stopped
        environment:
            - TZ=Europe/Warsaw
        volumes:
            - 'home_assistant_config:/config'
        network_mode: host
        image: homeassistant/home-assistant
  mqtt:
        image: eclipse-mosquitto:2.0
        container_name: mqtt
        cpus: 1
        mem_limit: 1024m
        volumes:
            - mosquitto_data:/mosquitto
        ports:
            - "1883:1883"
            - "9001:9001"
        command: "mosquitto -c /mosquitto-no-auth.conf"
  zigbee2mqtt:
        image: koenkk/zigbee2mqtt
        container_name: zigbee2mqtt
        mem_limit: 1024m
        cpus: 1
        volumes:
             - zigbee2mqtt_data:/app/data
             - /run/udev:/run/udev:ro
        ports:
            - 8081:8080
        environment:
        devices:
            - /dev/ttyACM0:/dev/ttyACM0
  esphome:
    container_name: esphome
    image: esphome/esphome
    ports:
      - '6052:6052'
    environment:
      - ESPHOME_DASHBOARD_USE_PING=true
    volumes:
      - ./config/esphome/config:/config
      - ./config/esphome/cache:/cache
      - /etc/localtime:/etc/localtime:ro
volumes:
    zigbee2mqtt_data:
        external: false
    mosquitto_data:
        external: false
        driver: local
.env:
########################ustawienia kontenerow##################################
# primary user ID -> id -u
apps_puid=1000
# primary group ID -> id -g
apps_guid=1000
# should container be up after reboot ?  https://docs.docker.com/config/containers/start-containers-automatically/
apps_restartpolicy=unless-stopped
# all applications timezone https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
apps_timezone=Europe/Warsaw
Reactions: jerry1333
A jakbyś mógł powiedzieć jeszcze jak mogę sprawdzić te ustawienia u siebie?
OK nie o taką podpowiedź mi chodziło - a może ktoś wie, jak mogę włączyć supervisora, jeśli go nie mam?
rtfm Home Assistant Supervisor
zainstaluj sobie HAOS w Virtual Station i wtedy możesz się bawić dalej.
wg mojej wiedzy to tylko nakładka dla startu aplikacji
Ha w contenerze, brak supervisora. Nie idz ta droga. Zròb maszyne wirtualna I zainstaluj pelny obraz HA
Wysłane z mojego SM-X700 przy użyciu Tapatalka
  1. home assistant
  2. eclipse-mosquitto-1
  3. /whisper
  4. esphome
  5. mosquitto
  6. container station
  7. portainer
  8. portainer-ce
  9. mqtt
  10. home
  11. homeassistant
