lama16
11
11
TS-x69L
I would like to upgrade the rtorrent pro but i've seen that its might not be possible as its may not be compatible however I saw in another post
Help - rTorrent-Pro not working on my TS-669L
that it might be compatible
Anyone got it running on a EOL qnap using atom?
Firmware version: 4.3.4.0695 Build 20180830
Model name: QNAP TS-869L
CPU: Intel(R) Atom(TM) CPU D3701 @ 2.13Ghz
RAM: 3GB
RAM: 3GB
I've got it running on the following:
Firmware: 4.34.0752 Build 20181026
Model Name: QNAP TS-869 Pro
CPU: Intel® Atom™ CPU D2700 @ 2.13GHz
RAM: 3GB
I can't see why it wouldn't work on the TS-869L
I thought that when we upgraded the firmware from 4.2.2 to 4.3 it change the architecture to x64
Did you check Silas Mariusz Silas Mariusz guide for compatibility ?
FAQ - Compatible with QNAP NAS models/platforms (Hardware)
I added short video how to check that !
I see few issues - major one is libraries incompatibility
2nd one is performance - i know it's questionable , but we moving forward , not staying back , right ? ;)
Thanks I'll check soon
