Damian
Persona grata!
Q's Architect
Jan 22, 2016
770
160
195
114
TVS-x71
802.11ad
mam taki docker-compose.yml:
version: "3"
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    restart: always
    networks:
      default:
        ipv4_address: 192.168.1.107
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "67:67/udp"
      - "80:80/tcp"
      - "443:443/tcp"
    environment:
      TZ: 'Europe/Warsaw'
    volumes:
      - '/share/CACHEDEV1_DATA/Container/pihole/etc-pihole/:/etc/pihole/'
      - '/share/CACHEDEV1_DATA/Container/pihole/etc-dnsmasq.d/:/etc/dnsmasq.d/'
    dns:
      - 192.168.1.1
      - 127.0.0.1
      - 1.1.1.1
  portainer:
    image: portainer/portainer
    command: -H unix:///var/run/docker.sock
    ports:
      - 9000:9000
      - 8000:8000
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
      - /share/CACHEDEV1_DATA/Container/portainer:/data
    restart: always
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Warsaw
    networks:
       dnet:
          ipv4_address: 172.28.1.1
  sonarr:
    image: "linuxserver/sonarr"
    container_name: "sonarr"
    volumes:
      - /share/CACHEDEV1_DATA/Container/sonarr:/config
      - /share/CACHEDEV2_DATA/Rdownload/sabnzbd/Downloads/complete:/downloads
      - /share/CACHEDEV2_DATA/UGdrive/:/tv
    ports:
      - 8989:8989
    restart: always
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Warsaw
    networks:
       dnet:
          ipv4_address: 172.28.1.2
  radarr:
    image: "linuxserver/radarr"
    container_name: "radarr"
    volumes:
      - /share/CACHEDEV1_DATA/Container/radarr:/config
      - /share/CACHEDEV2_DATA/UGdrive/Movies:/movies
      - "/etc/localtime:/etc/localtime:ro"
    ports:
      - 7878:7878
    restart: always
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Warsaw
    networks:
       dnet:
          ipv4_address: 172.28.1.3
  sabnzbd:
    image: "linuxserver/sabnzbd"
    container_name: "sabnzbd"
    volumes:
      - /share/CACHEDEV1_DATA/Container/sabnzbd:/config
      - /share/CACHEDEV2_DATA/Rdownload/sabnzbd/Downloads/incomplete:/incomplete-downloads
    ports:
        - 8242:8080
        - 8243:9090
    restart: always
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Warsaw
    networks:
       dnet:
          ipv4_address: 172.28.1.4
  jackett:
    image: "linuxserver/jackett"
    container_name: "jackett"
    volumes:
      - /share/CACHEDEV1_DATA/Container/jackett:/config
    ports:
      - 9117:9117
    restart: always
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Warsaw
    networks:
       dnet:
          ipv4_address: 172.28.1.5
  watchtower:
    image: containrrr/watchtower
    command: jackett lidarr radarr sabnzbd sonarr pihole nextcloud --cleanup
    volumes:
    restart: always
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Warsaw
    networks:
       dnet:
          ipv4_address: 172.28.1.7
  lidarr:
    image: linuxserver/lidarr
    container_name: lidarr
    environment:
      - PUID=0
      - PGID=0
      - TZ=Europe/Warsaw
    volumes:
      - /share/CACHEDEV1_DATA/Container/lidarr:/config
      - /share/CACHEDEV2_DATA/UGdrive/Music:/music
    ports:
      - 8686:8686
    restart: always
    networks:
       dnet:
          ipv4_address: 172.28.1.6
networks:
    dnet:
       ipam:
          driver: default
          config:
          - subnet: 172.28.0.0/16
    default:
       external:
sieci są następujące:
NETWORK ID          NAME                DRIVER              SCOPE
d500cd7fb94f        bridge              bridge              local
bd0f75b8ca62        container_default   bridge              local
ea316617040e        container_dnet      bridge              local
1404a9bb2d8e        host                host                local
696f84ab81f7        none                null                local
9861bc5de8a0        qnet-static-bond0   qnet                local
Czyli pihole ma adres z sieci lokalnej 192.168.1.107, a reszta ma adresy w: 172.28.1.*
Problemy są następujące:
1) Jak jestem podłączony przez OpenVPN i wykonam polecenie:
docker-compose down
zrywa połączenie VPN
2) Po zatrzymaniu contenerów i uruchomieniu np pojedyńczego:
docker-compose up sonarr
pojawia się komunikat, że nie może rozwinąć adresów stron - jakby problem z DNS w tym kontenerze. Nie można się również dostać do danej aplikacji przez www. Pomaga ponowne uruchomienie serwera.
Jakiś pomysł co mogę zmienić/poprawić? Chciałbym aby IP'ki pozostały te same.
Wersja oprogramowania Firmware: 4.5.1
Model serwera: QNAP TVS-671
  1. Watchtower
  2. radarr docker
  3. lidarr
