Iceman_jkh
7 Sierpień 2019
26
TVS-x71
Hi,
Hope you are staying safe!
I may have found a bug in rutorrent when using the 'directory' setting from radarr/sonarr...or I'm just not using it correctly.
When I don't use a save to Directory (i.e.:field is left blank), the files/folders always (or at least 95%) get moved to the 'completed' folder after downloading.
When using the Directory (as in above pic), the completed download is never moved there (<1% of the time) and when I click Delete and Remove Data.. it doesn't delete anything. I think the last part is because it's trying to delete it from the completed/'save to' directory, but the files aren't there.
My autotools are set like this:
I've also tried checking 'Add torrent's label to path'
In all cases, the files are downloaded into the Download directory, or the Download/'directory from sonarr/radarr'.
When using a Directory in sonarr/radarr, they never get moved to completed upon completion of downloading - neither into the main Completed directory nor a directory named after their tag/label/sonarr/radarr setting.
Please let me know if you can replicate this or if you want any more info
Thanks.
Firmware version: 0.9.7-A229 Build 20200312
Model name: QNAP TVS-671
Thanks _Floyd..
So is there any way to get ruTorrent to store the downloads (for sonarr/radarr) in a particular subfolder other than just using the base folder of 'downloads' and the base folder of 'complete' (for completed downloads)?
Thanks again. I think I'm asking for something different to what you're explaining, so I'll try clarify.
Normally, rutorrent downloads sonarr/radarr content into the "/rutorrent/downloads" directory.
/rutorrent/downloads/largefile.iso
/rutorrent/downloads/Movie[2010]/
It then moves completed downloads into the "/rutorrent/complete" directory.
/rutorrent/complete/largefile.iso
/rutorrent/complete/Movie[2010]/
I'm trying to get it to download content to a specifically named subdirectory within the downloads directory, with the name being set by radarr/sonar itself or the torrent's label (also set-able from radarr/sonar).
That would look like this:
/rutorrent/downloads/sonar/largefile.iso
/rutorrent/downloads/sonar/Movie[2010]/
and
/rutorrent/complete/sonar/largefile.iso
/rutorrent/complete/sonar/Movie[2010]/
If I get that working, I think radarr/sonarr will import the files correctly as it usually does.
  1. sonar
  2. sonar torrent
