Hi
I got Rtorrent pro a couple of weeks ago and it is great. But i have a problem with my port forwarding that
i need to ask you about.
When i start rtorrent - everything is fine, connections work just as they should.
After normally 2-4 days rtorrent reports that the port is closed. If i restart rtorrent everything is "green" again for a couple of
days and then i need to restart it again. All other forwarded ports work as they should.
I have tried both manual port forward and let the rtorrent open it automaticly - Same problem on both
Firmware version: 4.5.1 Build 20210107
Model name: QNAP TS-453
Regards
Niklas
Regards
Niklas
