Pomoc rtorrent-Pro not able to install on armv7l with QTS 5.0.1
flomo484
23 Styczeń 2020
TS-x31
Hi,
I bought rtorrent-pro today, unfortunately it is not possible to install the "0.9.6-0417" "TS-X41" on my TS-431XeU with an armv7l.
I get the attached error message.
Applications without a valid signature are of course active.
Is there any other possibility here except downgrading to QTS 5.0.0?
  • Failed to install rtorrent-Pro. Downgrade QTS to 5.0.0 or an older compatible version..jpg
mam ten sam problem co kolega powyżej na moim TS-233 - żadna z zakupionych dzisiaj wersji nie może być zainstalowana:
Czy jest jakaś szansa na otrzymanie kompatybilnej wersji?
Pozdrawiam.
I had a TS-431XeU and I bought Rtorrent-Pro from qnapclub few years ago.
Everything was ok with the old version ( 0.9.6-0417 ) until few days ago when my system was upgraded to QTS 5.0.1.2277 . Now doesn't work any more and I receive an error that isn't compatible with my QTS version.
I can do something to make it work? Or that was the end.
  1. rtorrent
  2. *
  3. rtorrent-pro
  4. qpkg for ARM
  5. install rtorrent
