Pomoc Total upload speed limited to 1.2Mib/s
n4n
26 Kwiecień 2023
25
TVS-871
Regardless of settings rTorrent upload speed does not go above 1.2Mib/s on 50MbE connection with multiple torrents bandwidth is split. Tried different configurations, no love.
I hope developer checks the forums from time to time.
I will try for a week to load more torrents to see if it's just an error due to the same ppl downloading with slow connections, then I'll update the post.
Download has not changed after a day, still slow about 20 KiB/s for Ubuntu Live image.
I hope the developer at least can give me some tips on how to resolve the issue considering the port forwarding is set up correctly.
Can you troubleshoot slow download? I don't mind paying. Although I am on the Mac, QNAP-1282 should not really be affected by this. I do think that slow download is rTorrent related, because I installed paid Deluge today and it downloads Ubuntu image very fast.
rTorrent settings "Connection"
can you set limits to ZERO ?
beside - that is rutorrent panel
rtorrent has settings panel i think, it was running on port 6008 ?
while are you there - check if ipfilter is disabled - that was problematic in past too
Set upload/download speed 0/0 in rTorrent ui, no change. Download speed stack at 1.2MiB/s, tried with/without "Boost Network Performance Throughput" _ no change
Any support options besides "I don't know"?
  1. openvpn
  2. qnapclub
  3. iperf
  4. POrt forwarding
  5. docker status
  6. Open VPN
  7. Entware-std
  8. Entware
  9. RTorrent port
