- 5 Kwiecień 2008
- 10 550
- 2 669
- 405
- Odznaki
- 205
- QNAP
- TS-x77
- Ethernet
- 1 GbE
Symptoms
Cause
An update keeps the settings, the accounts and passwords, the certificate, the categories, the notifications, the tracker accounts, the RSS feeds and rules, and the torrent list. Removing the package deletes the whole package folder, and with it the settings, accounts, passwords and the certificate. It also deletes the torrent list, because rtorrent keeps it with the package by default. The base folder on the share stays: the downloaded and completed files, the watch folder, the media library, and the
Resolution
Notice & Advise
Ref. links:
Rtorrent 16 guide: Installation
- You want to update Rtorrent 16 and do not know whether you will lose your settings or the torrent list.
- You want to remove the package or install it again, and keep the downloaded files and the torrent list.
Cause
backups/ folder with the daily copies of the torrent list and the configuration.Resolution
- Install an update over the installed package, without removing it first. A package from the repository updates in App Center; one you installed by hand takes the newer file through "Install Manually".
- Before you remove the package, open Settings → Files & storage. If Where rtorrent keeps its session is set to With the package, choose In the base folder.
- Press Review & save, then Save 1 change, and confirm with Move. The torrent list goes to the
session/folder in the base folder, which a removal leaves alone. - After installing again, choose In the base folder there once more. The panel merges the saved list into the current one.
Notice & Advise
- Every day the package saves a copy of the torrent list and of the configuration in the
backups/folder of the base folder, the last 14 by default. Back up now in the Backups card on Diagnostics takes a copy of this moment. If the base folder is in the same place after you install again, restore the torrent list and the configuration from these copies in the same card. - The configuration copy holds the panel password and the tracker logins. Treat it like a password.
Ref. links:
