- 5 Kwiecień 2008
- 10 550
- 2 669
- 405
- Odznaki
- 205
- QNAP
- TS-x77
- Ethernet
- 1 GbE
Symptoms
Cause
Rtorrent 16 is freeware: it costs nothing, and it has no licence key and no paid tier. You may use it free of charge on any number of QNAP NAS units that you own or administer, for private or business purposes. You install the package in App Center, from the QNAP Utilities repository or from a downloaded file. It runs on QTS 6.0 or QuTS hero 6.0 or later, with an Intel, AMD or 64-bit ARM processor.
Resolution
Notice & Advise
Ref. links:
Rtorrent 16 guide: Installation
- You look for Rtorrent 16 in App Center and do not know where to install it from.
- You want to know whether the package costs anything or needs a licence key.
Cause
Resolution
- In App Center, open "Settings" (the gear icon), then "App Repository" and "Add".
- Enter the name
QNAP Utilitiesand the URLhttps://www.qnaputilities.com/repo.xml, then press "Add". - Open QNAP Utilities in App Center's left rail and install Rtorrent 16. App Center installs the package on the volume you choose, starts it and later offers its updates.
- Without the repository: download the file for your processor from
https://pub.qnaputilities.com/rtorrent16/download/(the file ending in_x86_64.qpkgfor Intel and AMD, or in_arm_64.qpkgfor 64-bit ARM). In App Center, choose "Install Manually" and pick that file. App Center offers no updates for a package installed this way, so you install a newer file the same way.
Notice & Advise
- Supporting the project is voluntary. The Support page in the menu shows how to support it once or every month through Stripe.
- One day after the install, the panel shows a Rtorrent 16 is freeware window. Later puts it off for 24 hours, and I already do turns the reminder off on this NAS for good. The panel checks nothing.
- Do not install the package from the console with
sh. App Center then counts it as unsigned and turns it off.
Ref. links:
