Not open for further replies.
girkers
15
14
Australia
TS-x69 Pro
I have just installed R16 and it is SOOOO Much bigger than r15, I am being overwhelmed by the choices.
I will start with my directory questions:
  • I went through and changed all my directories and when I look at diagnostics, there is stuff in /share/ZFS2_DATA/Public/rtorrent16 but I don't want it there. How do I move it?
  • I just want a few media directories in watch/download, I don't need all 12 folders. Can I just have the ones I want or is it all or nothing?
  • Torrents aren't deleting from the watch folder, they just stay there. The system created the watch folder it, so I thought it would have set the correct permissions.
Kodi - I have set kodi to notify: http://x.x.x.x:8080/jsonrpc and the check passes, and in the log it shows "media servers asked to scan: Kodi" but the new download never appears. I can't find any log file to see exactly what it is doing. On my r15 setup it was set to x.x.x.x:9090 and it worked fine, but r16 won't take that URL. What is the correct set up for this, or where do I find the log file so I can troubleshoot?
On some setting pages at the top right it is showing "x settings need an rtorrent restart". I have restarted the server, but this is still showing. Does this always remain visible even after restart?
I appreciate all the work that has gone into this.
Cheers
I'm sorry for AI Bot, Rtorrent16 is totally new
This is info tip, which tell you that those settings changes requires restart.
Previously it was handled by filebot, have you installed and activated filebot? We're moving to independent Movie Agent, if you use it already I'll need to check this and maybe add an test button.
Uncheck creating labels in settings. However since QNAP users are very known for handlind tousands of torrents same time, categories are very important thing and its primary feature here.
Thats correct.
logs shouldnt be there anyway
you have to upgrade rtorrent16 qpkg and try kodi trigger again with test button + from gui change logs location
I have updated to the latest package and did the Kodi check and got this back: "Kodi answered at http://192.168.72.90:8080 in 5 ms (Kodi 21.3). A new file appears once a Kodi source covers the library folder." And it appears to be working as I would expect from a sample of 1. Thanks.
To confirm this is for information only, as I have restarted multiple times and the tip is still there.
Thats correct.
So how do I fix the watch folder to allow it to delete torrents one they are added?
I have the Logs folder set to "Beside the downloads" but there is no "logs" folder there.
FYI, I bought a Filebot license as I like how it worked for the most part in r15.
create a new thread here: "[Feature] auto-delete .torrent files in watch"
Movie Agent didnt worked well? i think its better try to stay on movie agent it does not require java, works pretty faster ...
Cześć girkers girkers 👋
Minęło kilka dni od ostatnich odpowiedzi w Twoim wątku. Czy udało Ci się rozwiązać problem?
  • Jeśli tak — napisz proszę krótko, co pomogło, i jeśli to możliwe, oznacz najtrafniejszą odpowiedź jako rozwiązanie. Kolejna osoba z tym samym problemem znajdzie wtedy gotową ścieżkę, zamiast szukać godzinami.
  • Jeśli jeszcze nie — daj znać, na czym stanęło i co już zostało sprawdzone. Wątek jest wciąż otwarty i chętnie pomożemy dalej.
przy okazji... Jak oceniasz nasze wsparcie na forum QNAP? Czy czas reakcji był w porządku? Jeśli któraś z odpowiedzi była szczególnie trafna — zagłosuj na nią strzałką w górę ▲. Jeśli była pomocna, ale jedynie nakierowała Cię na rozwiązanie — możesz zostawić ją bez głosu. A jeśli któraś okazała się błędna — śmiało zagłosuj strzałką w dół ▼.
Ta wiadomość jest automatyczna — wysłał ją bot forum według stałego szablonu. To nie jest odpowiedź asystenta AI: nikt i nic nie analizowało tu treści Twojego wątku.
Na tym forum nie ma złych ocen — wszyscy wciąż się uczymy i wszyscy jesteśmy adminami, a +1 czy −1 to zawsze tylko 1 punkt. Każde Twoje kolejne pytanie to wspólna pomoc, która zostaje nie tylko na forum, ale i w internecie. Społeczność forum QNAP działa od 2008 roku i po niemal dwóch dekadach nieprzerwanie dostarcza treści, z których korzystają kolejni admini — a ostatnio uczy się na nich także AI.
