QTS 4.4.1.0949 Build 20190528 beta
[Important Notes]
- For the status of QTS updates and maintenance for your NAS model, visit Product Support Status :: QNAP
- We have fixed the vulnerabilities in the following apps to ensure your data security: Surveillance Station, QVPN Service, Qfiling, Qsync Central, QcalAgent, and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.4.1 supports, see QNAP Systems, Inc. - Network Attached Storage (NAS)
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: "phpEasyProject", "Dolphin", "CMS Made Simple", "Vtiger CRM", "iStat", and "PostgreSQL".
- QTS 4.4.1 currently does not support QcalAgent or Notes Station 2. QNAP will add support for these applications in upcoming updates.
[New feature]
Control Panel - Multimedia Console
- Replaced Multimedia Management with Multimedia Console.
- Added support for sorting and hiding categories.
- Added feature that automatically uses image files as thumbnails for videos with the same filename.
- Added volume control function.
- Added support for new movie and TV show categories.
Virtualization Station
- vQTS 4.4.1 supports local installation via HTML5 console.
Control Panel - Hardware
- vQTS 4.4.1 supports GPU pass-through from Virtualization Station. This makes the resources of the assigned GPU available for use by the apps/services of that vQTS.
Encyption
- Added support for managing shared folder encryption in File Station.
File Station
- Added support for document collaboration via Microsoft Office Online.
Qtier
- Added support for removing the ultra-high speed (SSD) tier from a Qtier auto-tiering storage pool.
Snapshot
- Added Smart Snapshot Retention feature. Snapshots can now be retained by time period (hourly, daily, weekly, monthly).
Storage Management
- Added support for creating hardware-encrypted storage pools using SED drives.
- Added support for creating a one-time scheduled file system check.
- Storage & Snapshots now tracks and displays the estimated remaining life of SSDs.
- Added support for Fibre Channel storage protocol.
- QNAP drive adapters QDA-A2AR and QDA-A2MAR can now be used to create NAS storage space.
- QNAP drive adapter QDA-UMP can now be used to create NAS storage space.
User Group
- Added quota support for user groups.
Encyption
- File Station supports encryption and decryption for files with the ".qenc" extension.
Expansion Card
- Added support for Mustang-F100 FPGA and Mustang-V100 VPU cards. You can go to Control Panel and assign them as resources for the OpenVINO™ Workflow Consolidation Tool.
App Center
- Added support for validating digital signatures and certificates.
CacheMount
- Files on mounted Google Drive accounts (.gdoc, .gslides, .gsheet) can now be downloaded as Microsoft Office files (.docx, .pptx, .xlsx) in File Station.
Network and Virtual Switch
- Added support for displaying Fibre Channel adapter information and status.
Resource monitor
- Added support for displaying kernel processes on the system processs category.
File Sharing Protocol
- Added support for Samba 4.7.
[Enhancement]
CacheMount
- The new CacheMount application has replaced remote mount in File Station. Install CacheMount from the App Center to keep using remote mount services.
Control Panel - Daylight SavingTime
- Added support for cross-year daylight saving time settings.
- Moved Media Streaming Add-on to App Center repository.
QTS - Security
- Added version settings for TLS.
- Added support for HTTP compression.
UPS
- Added support for up to 20 UPS devices.
Web Server
WebDAV
- WebDAV is now disabled by default.
Storage Management
- Updated IronWolf Health Management (IHM) to support new Seagate IronWolf and IronWolf Pro drive models.
- QTS can now check for firmware updates for connected expansion devices and then prompt you to update them each time you log in.
- Added indicators for interfaces that support WoL.
File Station
- Added support for checking access logs in file or folder properties in File Station.
Performance
- Reduced and optimized the maximum latency for SSD storage space.
[Other Changes]
Library
- Updated to SQLite 3.26.0.
- Updated the Apache version to 2.4.39.
- Updated the PHP version to 7.3.4.
File Station
- Removed the "Show files and folders of my PC" function from File Station.
[Download]
https://download.qnap.com/Storage/HS-251/HS-251_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/Mustang-200/Mustang-200_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/QB-103/QB-103_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-KVM/TS-KVM_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X28A/TS-X28A_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X32/TS-X32_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X32U/TS-X32U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X35A/TS-X35A_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X51B/TS-X51B_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X53II/TS-X53A_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X53D/TS-X53D_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/SS-X53/TS-X53S_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X72/TS-X72_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X72U/TS-X72U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X77/TS-X77_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X77U/TS-X77U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X83XU/TS-X83XU_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X88/TS-X88_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-XA28A/TS-XA28A_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-XA51/TS-XA51_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-XA73/TS-XA73_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-XA82/TS-XA82_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X63/TVS-X63_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X71/TVS-X71_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X71U/TVS-X71U_20190528-4.4.1.0949.zip
https://download.qnap.com/Storage/TS-X73/TVS-X73_20190528-4.4.1.0949.zip
[Important Notes]
[New feature]
Encyption
File Station
Qtier
Snapshot
Storage Management
User Group
Encyption
Expansion Card
App Center
CacheMount
Resource monitor
[Enhancement]
CacheMount
QTS - Security
UPS
Web Server
WebDAV
Storage Management
File Station
Performance
[Other Changes]
Library
File Station
[Download]
