- 5 Kwiecień 2008
- 10 550
- 2 669
- 405
- Odznaki
- 205
- QNAP
- TS-x77
- Ethernet
- 1 GbE
Symptoms
Cause
The package keeps a journal of every start, stop, restart and crash of rtorrent, with who asked for it and why. The watchdog checks every 5 minutes. When it finds rtorrent dead although it should run, it records the reason, starts rtorrent again and sends a notification. The reason is the kernel's out-of-memory killer or the last line of rtorrent's log. When rtorrent does not start, the journal says why, for example that another rtorrent uses the session folder.
Resolution
Notice & Advise
Ref. links:
Rtorrent 16 guide: Control Center
- Torrents stopped, and the Dashboard shows rtorrent stopped.
- rtorrent does not start, or it stops again after a while.
Cause
Resolution
- Open the Dashboard and read the rtorrent badge at the start of the state strip. While rtorrent is down, it reads rtorrent stopped · …, … with who stopped it and when. For a day after a crash, a line above the strip reads rtorrent crashed …: … with the reason.
- Read the Activity card further down the page. Each line has the time, the engine, what happened and who did it. Show more lists more lines. The lines are in English in every language of the panel; a crash reads "rtorrent exited on its own" with the reason.
- Make a diagnostic dump. Press Diagnostic dump at the top of Diagnostics, or the same link in the crash line on the Dashboard. Keep Not about a specific torrent and press Create dump. The window lists the files in the dump and what was taken out of them: passwords, keys, tokens and tracker passkeys go, and the torrents become numbers such as [torrent-3].
- Press Download (…) and send the file to whoever helps you. The window can also prepare a forum post with a link to the dump: under Ask for help on the forum, press Create LinkDrop link, write what happens in the first line of Post for the forum and press Copy post. Then press Open the Rtorrent 16 thread and paste the post as a reply.
Notice & Advise
- Before you post, read the pinned thread "Rtorrent16: How to report ANY issues and software status" in the forum's Rtorrent 16 section.
- When the panel does not open, make the dump over FAQ SSH with
/etc/init.d/rtorrent16.sh diag. Its "file" line is the path of the dump. - When the reason names the out-of-memory killer, lower Max memory for pieces (MiB) in Settings → Bandwidth & limits.
Ref. links:
