krystianen
System Engineer
Q Specialist
25 Styczeń 2010
102
135
Poznań
Wersja oprogramowania Firmware: 4.4.1 Build 20YYMMDD
Model serwera: QNAP TS-251A
Zainstalowałem PI HOLE na dockerze jednak podczas uruchomienia mam bład
Czy ktoś się spotkał z takim problemem?
[✗] DNS resolution is currently unavailable
Doszukałem się że musze ze musze zedytować DNSy w pliku /etc/resolf.conf tylko nie wiem jak sie mam do niego stać. Bo wyrzuceniu w/w błedy pi hole sie wylacza.
 ::: Starting docker specific checks & setup for docker pihole/pihole
WARNING Misconfigured DNS in /etc/resolv.conf: Two DNS servers are recommended, 127.0.0.1 and any backup server
WARNING Misconfigured DNS in /etc/resolv.conf: Primary DNS should be 127.0.0.1 (found 127.0.0.11)
nameserver 127.0.0.11
options ndots:0
Assigning random password: -6wj8quc
  [i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u5
  [i] Installing configs from /etc/.pihole...
  [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone!
  [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Setting password: -6wj8quc
+ pihole -a -p -6wj8quc -6wj8quc
  [✓] New password set
Using default DNS servers: 8.8.8.8 & 8.8.4.4
DNSMasq binding to default interface: eth0
Added ENV to php:
                        "PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
                        "ServerIP" => "0.0.0.0",
                        "VIRTUAL_HOST" => "0.0.0.0",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
https://mirror1.malwaredomains.com/files/justdomains
http://sysctl.org/cameleon/hosts
https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
https://hosts-file.net/ad_servers.txt
::: Testing pihole-FTL DNS: FTL started!
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
::: Docker start setup complete
  [i] Pi-hole blocking is enabled
  [✗] DNS resolution is not available
[cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Super, sam skorzystam. po prostu zapytam. Jak mogę zaktualizować do nowszej wersji, która będzie dostępna po 2 miesiącach od instalacji i konfiguracji?
Teraz mam PiHole na Raspberry PI i tam przez FAQ SSH wprowadza się polecenie pihole-up i instaluje się aktualizacje. Ale tu na QNAP?
jeśli korzystasz z compose , to jerry1333 jerry1333 zapodał skrypt do update'a
jeśli wyklikałeś z GUI, to bawisz się dobrze :p
polecam portainera - bo tam jest taki fajny guzik:
Wracam zmieniłem operatora i wszystko działa :D szkoda tylko, że w nowym funbox 6 nie da się zmienić dns'ów i zaś zostaje mi je wpisywać ręcznie na urządzeniach :p ale chociaż działa jeszcze ogarniam listy, bo wp to jakiś kosmos i tak reklamy dostaje na telefonie ale mam nadzieje, że w końcu coś znajdę :p
a robiąc recreate listy też się przenoszą ?
Znalazłem też info, że nie ma opcji blokowania reklam na YT poprzez DNS bo google używa tego samego dns do reklam i filmów... serio się nie da?
Kurde jak to jest mam adguard premium na telefonie, jak go wlacze wyszstkie reklamy z wp.pl wyciete, przez pihole nie ma takiej opcji... :F troche marny to bloker
nic nowego :)
tak .. no chyba że pan instalator coś spierd...ił
Taki mamy klimat.
Jak już pisałem, Pihole blokuje domeny nie reklamy. AdGuard działa inaczej (uBlock też).
Chcesz skutecznie blokować reklamy i syf w Internecie? PiHole + Adguard / uBlock jako podstawa - jedno drugie uzupełnia
Reakcje: 0.1+0.2!==0.3
No miałem nadzieję, że jednak Pihole jest takim all-in-one ale nie jest to złoty środek a nawet sam AdGuard działa dużo lepiej niż pihole, cięzko niestety adguard'a mieć na telewizorze i na urządzeniach gości no i jeszcze kwestia adguard na telefonie wymusza współpracę tylko na 2óch przeglądarkach jak ktoś się tam przyzwyczaił do innej niż samsung internet albo yandex to ciężko to pogodzić.
Ależ oczywiście że jest all-in-one tylko Ty oczekujesz od niego czegoś do czego nie był stricte zaprojektowany. Jak masz dzieci masz białą i czarną listę adresów względnie sprawdzasz ruch kto co ogląda kontrola najwyższą formą zaufania ;)
Twoja sytuacja nie rzutuje bo przez fakt że nie masz żadnej kontroli nad urządzeniem providera korzystanie z pi-hole użytkowników jest niearbitralne (w zasadzie nigdy nie jest) ale domyślnie w Twojej sieci "mogło by być".
Używam Pihole choć nie jest idealny..Adguard możesz używać równolegle w sieci z Pihole.
Jednak webmasterzy opracowują patenty za które dostają $ żeby treści sponsorowane były publikowane..taka rola internetu.
Stosując jednak mechanizmy ww. aplikacji plus dodatków do przeglądarek można osiągnąć pożądany efekt..
dla przykładu jak blokuje u mnie pihole popularne serwisy onet i wp.pl
  1. pihole
  2. adguard
  3. *
  4. netflix
  5. pi hole
  6. container sieć
  7. docker status
  8. localhost docker
  9. cont
  10. active directory
  11. filtry
  12. ls proc
  13. pihole docker
  14. pihole listy
  15. ubuntu station
  16. dns domain forward
  17. drukarka
  18. qnet
  19. switch do 10 gbe
  20. reject md5 servers = yes
  21. pihole docker-compose
  22. container settings
  23. samsung evo 970
  24. docker proc
  25. pihole konfiguracja
  26. Listy do pihole
  27. pi-hole
