krystianen
System Engineer
Q Specialist
25 Styczeń 2010
102
135
Poznań
Wersja oprogramowania Firmware: 4.4.1 Build 20YYMMDD
Model serwera: QNAP TS-251A
Zainstalowałem PI HOLE na dockerze jednak podczas uruchomienia mam bład
Czy ktoś się spotkał z takim problemem?
[✗] DNS resolution is currently unavailable
Doszukałem się że musze ze musze zedytować DNSy w pliku /etc/resolf.conf tylko nie wiem jak sie mam do niego stać. Bo wyrzuceniu w/w błedy pi hole sie wylacza.
 ::: Starting docker specific checks & setup for docker pihole/pihole
WARNING Misconfigured DNS in /etc/resolv.conf: Two DNS servers are recommended, 127.0.0.1 and any backup server
WARNING Misconfigured DNS in /etc/resolv.conf: Primary DNS should be 127.0.0.1 (found 127.0.0.11)
nameserver 127.0.0.11
options ndots:0
Assigning random password: -6wj8quc
  [i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u5
  [i] Installing configs from /etc/.pihole...
  [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone!
  [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Setting password: -6wj8quc
+ pihole -a -p -6wj8quc -6wj8quc
  [✓] New password set
Using default DNS servers: 8.8.8.8 & 8.8.4.4
DNSMasq binding to default interface: eth0
Added ENV to php:
                        "PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
                        "ServerIP" => "0.0.0.0",
                        "VIRTUAL_HOST" => "0.0.0.0",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
https://mirror1.malwaredomains.com/files/justdomains
http://sysctl.org/cameleon/hosts
https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
https://hosts-file.net/ad_servers.txt
::: Testing pihole-FTL DNS: FTL started!
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
::: Docker start setup complete
  [i] Pi-hole blocking is enabled
  [✗] DNS resolution is not available
[cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
QQryq QQryq - pamietaj ze kolega jerry1333 jerry1333 robił to na klasycznym linuxie ,
ty w QNAPie musisz robić foldery w /share/...
dla testów, proponuje cd /share/Public
przed wykonaniem poniższego kodu
Reakcje: jerry1333
wszystko stworzone ale przy komendzie ./run.sh mam błąd
pihole]$ /run.sh
-sh: /run.sh: No such file or directory
jestem aktualnie w /share/Public/pihole więc nie muszę tego z całej ścieżki wywoływać a jednak nie chce coś przyjąć
oczywiście zawartość wyedytowałem tak jak miałem
[herotech@Herotech pihole]$ sh run.sh
Creating pihole ...
Creating pihole ... error
ERROR: for pihole Cannot start service pihole: driver failed programming external connectivity on endpoint pihole (74fca889d8257ce385200ba3edd3249b1ab5f677a0ff1dd6cbc468497275634c): listen udp4 0.0.0.0:67: bind: address already in use
ERROR: Encountered errors while bringing up the project.
version: '3.8'
services:
pihole:
container_name: pihole
environment:
TZ: 'Europe/Warsaw'
WEBPASSWORD: 'tatatatatatatata'
ADMIN_EMAIL: 'super@admin.net'
IPv6: false
PIHOLE_UID: 1000
PIHOLE_GID: 100
hostname: pi.hole
image: pihole/pihole:latest
network_mode: bridge
ports:
- 53:53/tcp
- 53:53/udp
- 67:67/udp
- 8080:80/tcp
restart: always
volumes:
- '/home/pi/pihole/data:/etc/pihole/'
- '/home/pi/pihole/data-dnsmasq:/etc/dnsmasq.d'
- '/home/pi/pihole/data/overwrite_resolv.conf:/etc/resolv.conf'
deploy:
resources:
limits:
cpus: '4'
memory: 1024M
a tego używam
  1. pihole
  2. adguard
  3. *
  4. netflix
  5. pi hole
  6. container sieć
  7. container settings
  8. samsung evo 970
  9. docker proc
  10. pihole konfiguracja
  11. Listy do pihole
  12. docker status
  13. localhost docker
  14. cont
  15. active directory
  16. filtry
  17. ls proc
  18. pihole docker
  19. pihole listy
  20. ubuntu station
  21. dns domain forward
  22. drukarka
  23. qnet
  24. switch do 10 gbe
  25. reject md5 servers = yes
  26. pihole docker-compose
