krystianen
System Engineer
Q Specialist
25 Styczeń 2010
102
135
Poznań
Wersja oprogramowania Firmware: 4.4.1 Build 20YYMMDD
Model serwera: QNAP TS-251A
Zainstalowałem PI HOLE na dockerze jednak podczas uruchomienia mam bład
Czy ktoś się spotkał z takim problemem?
[✗] DNS resolution is currently unavailable
Doszukałem się że musze ze musze zedytować DNSy w pliku /etc/resolf.conf tylko nie wiem jak sie mam do niego stać. Bo wyrzuceniu w/w błedy pi hole sie wylacza.
 ::: Starting docker specific checks & setup for docker pihole/pihole
WARNING Misconfigured DNS in /etc/resolv.conf: Two DNS servers are recommended, 127.0.0.1 and any backup server
WARNING Misconfigured DNS in /etc/resolv.conf: Primary DNS should be 127.0.0.1 (found 127.0.0.11)
nameserver 127.0.0.11
options ndots:0
Assigning random password: -6wj8quc
  [i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u5
  [i] Installing configs from /etc/.pihole...
  [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone!
  [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Setting password: -6wj8quc
+ pihole -a -p -6wj8quc -6wj8quc
  [✓] New password set
Using default DNS servers: 8.8.8.8 & 8.8.4.4
DNSMasq binding to default interface: eth0
Added ENV to php:
                        "PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
                        "ServerIP" => "0.0.0.0",
                        "VIRTUAL_HOST" => "0.0.0.0",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
https://mirror1.malwaredomains.com/files/justdomains
http://sysctl.org/cameleon/hosts
https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
https://hosts-file.net/ad_servers.txt
::: Testing pihole-FTL DNS: FTL started!
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
::: Docker start setup complete
  [i] Pi-hole blocking is enabled
  [✗] DNS resolution is not available
[cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Ok zaloguj się jeszcze raz nie potrzebujesz tego (PuTTY) padła aby się logować masz wind 10 lub 11 wbudowany cmd lub inny terminal powinien sobie poradzić bez problemu bez jakiejkolwiek konfiguracji
oczekiwałem zobaczyć coś takiego:
[eee@NAS ~]$ echo $PATH
/share/ZFS532_DATA/.qpkg/container-station/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/bin/X11:/usr/local/sbin:/usr/local/bin
Jak widać w ścieżce jest odwołanie do docker'owych plików u Ciebie nie ma żadnych co jest dość dziwne.
mamy to :p
tak z komenda sudo which docker
czyli teraz powinienem stworzyć sieć dla dokera ? przy przejść do uruchomienia run.sh ?
przy próbie dodania sieci:
dobra widzę, że muszę stworzyć tą sieć bo nie chce odpalić
dla testu wpisałęm tylko docker network create qnet-static i poszło ale teraz przydałoby się to zdefiniować :p
czy ten wpis da się jakoś edytować czy go usunąć i stworzyć od nowa ?
Reakcje: 0.1+0.2!==0.3
nie, normalnie pracuje moge wejść na stronę pihola i dodać filtry ( ale kiedy robię update gravity to mam znow to samo - DNS resolution is currently unavailable )itp, ale nic nie filtruje, nawet jak ustawię na sztywno adres dns ( adres pihola ) na urządzeniu ( TV ) to i tak reklamy np. na yt są
robie testy problem z DNS Resolve caly czas jest, zrestartowałem kontener i coś się pokazało
problem w tym, że testuje na telefonie, tv i reklamy jak są tak są, czy to na portalach czy na yt, pihole wpisany ręcznie jako jedyny dns...
pihole ponoć daje sobie z tym radę, tak samo z reklamami na wp.pl itp... u znajomego na malince działa ;) ja na kompie nie potrzebuje bo adguarda premium używam ale dla dzieciakow na telefony, zony i tv ( ale bez androida - samsungi ) to najlepsza alternatywa by to powycinać
znalazłem taki tip tylko nie do końca wiem, jak to wykonać
If you are running docker with docker-compose, first run:
sudo docker exec -it pi-hole /bin/bash
Where pi-hole is the name of your container.
Do:
cat /etc/resolv.conf
Make note of everything in this file, or copy and paste.
Create a resolv.conf file in ypur docker-compose.yml directory and paste it in. Change nameserver to 127.0.0.1
Add a volume in docker-compose pointing this file to /etc/resolv.conf
Should look like:
- './resolv.conf:/etc/resolv.conf'
Restart the container.
Exec back into the container and try an apt update, if it works you should be good.
edytować to w FAQ SSH przez komende " vi " czy stworzyć plik i podmienić przez file station ?
Jeszcze pomyślałem, że może debug log coś pomoże:
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
NOTE: All log files auto-delete after 48 hours and ONLY the Pi-hole developers can access your data via the given token. We have taken these extra steps to secure your data and will work to further reduce any personal information gathered.
*** [ INITIALIZING ]
 2023-01-30:17:42:24 debug log has been initialized.
 System has been running for 0 days, 19 hours, 35 minutes
*** [ INITIALIZING ] Sourcing setup variables
 Sourcing /etc/pihole/setupVars.conf...
*** [ DIAGNOSING ]: Core version
[✓] Version: v5.15.3
 Remotes: origin    GitHub - pi-hole/pi-hole: A black hole for Internet advertisements (fetch)
             origin    GitHub - pi-hole/pi-hole: A black hole for Internet advertisements (push)
 Branch: master
 Commit: v5.15.3-0-gc7ad711
*** [ DIAGNOSING ]: Web version
[✓] Version: v5.18.3
 Remotes: origin    GitHub - pi-hole/AdminLTE: Pi-hole Dashboard for stats and more (fetch)
             origin    GitHub - pi-hole/AdminLTE: Pi-hole Dashboard for stats and more (push)
 Branch: master
 Commit: v5.18.3-0-gfb1b5c3
*** [ DIAGNOSING ]: FTL version
[✓] Version: v5.20.1
 Branch: master
 Commit: 47128aaf
*** [ DIAGNOSING ]: lighttpd version
 1.4.59
*** [ DIAGNOSING ]: php version
 7.4.33
*** [ DIAGNOSING ]: Operating system
 Pi-hole Docker Container: 2023.01.10
[✓] Distro:  Debian
[✓] Version: 11
[✓] dig return code: 0
 dig response: "Raspbian=10,11 Ubuntu=20,22 Debian=10,11 Fedora=36,37 CentOS=8,9"
[✓] Distro and version supported
*** [ DIAGNOSING ]: SELinux
 SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[✓] Firewalld service not detected
*** [ DIAGNOSING ]: Processor
[✓] x86_64
*** [ DIAGNOSING ]: Disk usage
   Filesystem             Size  Used Avail Use% Mounted on
   overlay                136G   18G  118G  14% /
   tmpfs                   64M     0   64M   0% /dev
   tmpfs                  3.9G     0  3.9G   0% /sys/fs/cgroup
   shm                     64M  972K   64M   2% /dev/shm
   /dev/mapper/cachedev1  136G   18G  118G  14% /etc/hosts
   tmpfs                  3.9G     0  3.9G   0% /proc/asound
   tmpfs                  3.9G     0  3.9G   0% /proc/acpi
   tmpfs                  3.9G     0  3.9G   0% /proc/scsi
   tmpfs                  3.9G     0  3.9G   0% /sys/firmware
*** [ DIAGNOSING ]: Network interfaces and addresses
   1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
       link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
       inet 127.0.0.1/8 scope host lo
          valid_lft forever preferred_lft forever
   17: eth0@if18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
       link/ether 02:42:95:cd:46:5d brd ff:ff:ff:ff:ff:ff link-netnsid 0
       inet 192.168.0.222/24 brd 192.168.0.255 scope global eth0
*** [ DIAGNOSING ]: Network routing table
   default via 192.168.0.1 dev eth0
   192.168.0.0/24 dev eth0 proto kernel scope link src 192.168.0.222
*** [ DIAGNOSING ]: Networking
[✓] IPv4 address(es) bound to the eth0 interface:
    192.168.0.222/24
[✗] No IPv6 address(es) found on the eth0 interface.
 Default IPv4 gateway(s):
     192.168.0.1
   * Pinging first gateway 192.168.0.1...
[✓] Gateway responded.
 Default IPv6 gateway(s):
*** [ DIAGNOSING ]: Name resolution (IPv4) using a random blocked domain and a known ad-serving domain
[✓] clientredirect-activemarketingpriv.dii1.ns-promovisionnet.net.zooplus.it is 0.0.0.0 on lo (127.0.0.1)
[✓] clientredirect-activemarketingpriv.dii1.ns-promovisionnet.net.zooplus.it is 0.0.0.0 on eth0 (192.168.0.222)
[✓] doubleclick.com is 142.251.208.142 via a remote, public DNS server (8.8.8.8)
*** [ DIAGNOSING ]: Name resolution (IPv6) using a random blocked domain and a known ad-serving domain
[✓] No IPv6 address available on lo
[✓] No IPv6 address available on eth0
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
*** [ DIAGNOSING ]: Discovering active DHCP servers (takes 10 seconds)
   Scanning all your interfaces for DHCP servers
   Timeout: 10 seconds
   * Received 320 bytes from eth0:192.168.0.1
     Offered IP address: 192.168.0.53
     Server IP address: 192.168.0.1
     Relay-agent IP address: N/A
     BOOTP server: (empty)
     BOOTP file: (empty)
     DHCP options:
      Message type: DHCPOFFER (2)
      netmask: 255.255.255.0
         router: 192.168.0.1
      default-ttl: 64
      lease-time: 3600 ( 1h )
      server-identifier: 192.168.0.1
      dns-server: 89.228.4.126
      dns-server: 31.11.173.2
      domain-name: "elblag.vectranet.pl"
      renewal-time: 1800 ( 30m )
      rebinding-time: 3150 ( 52m 30s )
      --- end of options ---
   DHCP packets received on interface lo: 0
   DHCP packets received on interface eth0: 1
*** [ DIAGNOSING ]: Pi-hole processes
[✓] lighttpd daemon is active
[✓] pihole-FTL daemon is active
*** [ DIAGNOSING ]: Pi-hole-FTL full status
 systemctl:  command not found
*** [ DIAGNOSING ]: Setup variables
    PIHOLE_INTERFACE=eth0
    IPV4_ADDRESS=0.0.0.0
    IPV6_ADDRESS=0:0:0:0:0:0
    QUERY_LOGGING=true
    INSTALL_WEB_SERVER=true
    INSTALL_WEB_INTERFACE=true
    LIGHTTPD_ENABLED=true
    CACHE_SIZE=10000
    DNS_FQDN_REQUIRED=true
    DNS_BOGUS_PRIV=true
    DNSMASQ_LISTENING=all
    DNSSEC=false
    REV_SERVER=false
    PIHOLE_DNS_1=8.8.8.8
    PIHOLE_DNS_2=1.1.1.1
    BLOCKING_ENABLED=true
*** [ DIAGNOSING ]: Dashboard headers
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Pi-hole FTL Query Database
-rw-rw-r-- 1 pihole pihole 344K Jan 30 17:42 /etc/pihole/pihole-FTL.db
*** [ DIAGNOSING ]: Gravity Database
-rw-rw-r-- 1 pihole pihole 12M Jan 30 17:22 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
   property              value
   version               15
   updated               1674682511
   gravity_count         172502
   Last gravity run finished at: Wed Jan 25 21:35:11 UTC 2023
   ----- First 10 Gravity Domains -----
   localhost.localdomain
   eu1.clevertap-prod.com
   wizhumpgyros.com
   coccyxwickimp.com
   webmail-who-int.000webhostapp.com
   010sec.com
   01mspmd5yalky8.com
   0byv9mgbn0.com
   ns6.0pendns.org
   dns.0pengl.com
*** [ DIAGNOSING ]: Groups
   id    enabled  name                                                date_added           date_modified        description
   0           1  Default                                             2023-01-25 21:35:09  2023-01-25 21:35:09  The default group
*** [ DIAGNOSING ]: Domainlist (0/1 = exact white-/blacklist, 2/3 = regex white-/blacklist)
*** [ DIAGNOSING ]: Clients
   id    group_ids     ip        date_added           date_modified        comment
   1     0             9A:54:C2:D2:CD:8B        2023-01-30 17:22:06  2023-01-30 17:22:06  telefon
*** [ DIAGNOSING ]: Adlists
   id     enabled  group_ids     address        date_added           date_modified        comment
   1            1  0             https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts                                      2023-01-25 21:35:09  2023-01-25 21:35:09  Migrated from /etc/pihole/adlists.list
   2            1  0             https://hole.cert.pl/domains/domains_hosts.txt                                                        2023-01-29 22:44:07  2023-01-29 22:44:07
   3            1  0             https://raw.githubusercontent.com/kboghdady/youTube_ads_4_pi-hole/master/youtubelist.txt              2023-01-29 22:44:08  2023-01-29 22:44:08
   4            1  0             https://v.firebog.net/hosts/AdguardDNS.txt                                                            2023-01-29 22:45:46  2023-01-29 22:45:46
   5            1  0             https://adaway.org/hosts.txt        2023-01-29 22:45:49  2023-01-29 22:45:49
   6            1  0             https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt                                            2023-01-29 22:45:55  2023-01-29 22:45:55
   7            1  0             https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt                            2023-01-29 22:45:59  2023-01-29 22:45:59
   8            1  0             https://v.firebog.net/hosts/Easylist.txt                                                              2023-01-29 22:46:07  2023-01-29 22:46:07
   9            1  0             https://raw.githubusercontent.com/PolishFiltersTeam/KADhosts/master/KADhosts.txt                      2023-01-29 22:46:14  2023-01-29 22:46:14
   10           1  0             https://github.com/MajkiIT/polish-ads-filter/tree/master/polish-pihole-filters                        2023-01-29 22:46:53  2023-01-29 22:46:53
   11           1  0             https://zerodot1.gitlab.io/CoinBlockerLists/hosts_browser                                             2023-01-29 22:48:29  2023-01-29 22:48:29
   12           1  0             https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.Risk/hosts                         2023-01-29 22:48:33  2023-01-29 22:48:33
   13           1  0             https://phishing.army/download/phishing_army_blocklist_extended.txt                                   2023-01-29 22:48:41  2023-01-29 22:48:41
   14           1  0             https://raw.githubusercontent.com/MajkiIT/polish-ads-filter/master/polish-pihole-filters/SmartTV_ads  2023-01-29 22:50:58  2023-01-29 22:50:58
                                 .txt
   15           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/urlhaus_filter_hosts.  2023-01-30 17:02:38  2023-01-30 17:02:38
                                 txt
   16           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/adguard_mobile_host.t  2023-01-30 17:03:40  2023-01-30 17:03:40
                                 xt
   17           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/Ad_filter_list_by_Dis  2023-01-30 17:03:47  2023-01-30 17:03:47
                                 connect.txt
   18           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/AdAway-hosts.txt       2023-01-30 17:03:55  2023-01-30 17:03:55
   19           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/Airelle-tracking.txt   2023-01-30 17:04:10  2023-01-30 17:04:10
   20           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/CryptoWall_Ransomware  2023-01-30 17:04:17  2023-01-30 17:04:17
                                 _C2.txt
   21           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/KADhosts.txt           2023-01-30 17:04:37  2023-01-30 17:04:37
   22           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/NoTrack_Tracker_Block  2023-01-30 17:04:41  2023-01-30 17:04:41
                                 list.txt
   23           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/Prigent-Ads-hosts.txt  2023-01-30 17:04:46  2023-01-30 17:04:46
   24           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/TeslaCrypt_Ransomware  2023-01-30 17:04:54  2023-01-30 17:04:54
                                 _Payment_Sites.txt
   25           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/adguard_crypto_host.t  2023-01-30 17:05:00  2023-01-30 17:05:00
                                 xt
   26           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/adguard_host.txt       2023-01-30 17:05:04  2023-01-30 17:05:04
   27           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/adguard_host_privacy.  2023-01-30 17:05:08  2023-01-30 17:05:08
                                 txt
   28           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/adservers.txt          2023-01-30 17:05:18  2023-01-30 17:05:18
   29           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/all_ads_filters.txt    2023-01-30 17:05:23  2023-01-30 17:05:23
   30           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/android-tracking-piho  2023-01-30 17:05:29  2023-01-30 17:05:29
                                 le.txt
   31           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/easy_privacy_host.txt  2023-01-30 17:05:35  2023-01-30 17:05:35
   32           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/easylist_host.txt      2023-01-30 17:05:56  2023-01-30 17:05:56
   33           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/firebog-Easylist.txt   2023-01-30 17:06:02  2023-01-30 17:06:02
   34           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/firebog-Easyprivacy.t  2023-01-30 17:06:06  2023-01-30 17:06:06
                                 xt
   35           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/gambling-hosts.txt     2023-01-30 17:06:20  2023-01-30 17:06:20
   36           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/hole_cert_pl.txt       2023-01-30 17:06:30  2023-01-30 17:06:30
   37           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/hostfile.txt           2023-01-30 17:06:39  2023-01-30 17:06:39
   38           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/hostfile_regex.txt     2023-01-30 17:06:45  2023-01-30 17:06:45
   39           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/kad_host.txt           2023-01-30 17:06:49  2023-01-30 17:06:49
   40           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/phishing_army_blockli  2023-01-30 17:06:54  2023-01-30 17:06:54
                                 st.txt
   41           1  0             https://github.com/MajkiIT/polish-ads-filter/blob/master/polish-pihole-filters/ublock_hosts.txt       2023-01-30 17:07:00  2023-01-30 17:07:00
*** [ DIAGNOSING ]: contents of /etc/pihole
-rw-r--r-- 1 root root 0 Jan 25 21:35 /etc/pihole/custom.list
-rw-r--r-- 1 root root 65 Jan 25 21:35 /etc/pihole/local.list
-rw-r--r-- 1 root root 241 Jan 25 21:35 /etc/pihole/logrotate
   /var/log/pihole/pihole.log {
       su root root
       daily
       copytruncate
       rotate 5
       compress
       delaycompress
       notifempty
       nomail
   /var/log/pihole/FTL.log {
       su root root
       weekly
       copytruncate
       rotate 3
       compress
       delaycompress
       notifempty
       nomail
-rw-rw-r-- 1 pihole root 193 Jan 30 17:20 /etc/pihole/pihole-FTL.conf
   PRIVACYLEVEL=0
   MACVENDORDB=/macvendor.db
   LOCAL_IPV4=127.0.0.1
   RATE_LIMIT=1000/60
-rw-r--r-- 1 root root 388 Jan 29 22:37 /etc/pihole/versions
   CORE_VERSION=v5.15.3
   CORE_BRANCH=master
   CORE_HASH=c7ad7113
   GITHUB_CORE_VERSION=v5.15.3
   GITHUB_CORE_HASH=c7ad7113
   WEB_VERSION=v5.18.3
   WEB_BRANCH=master
   WEB_HASH=fb1b5c31
   GITHUB_WEB_VERSION=v5.18.3
   GITHUB_WEB_HASH=fb1b5c31
   FTL_VERSION=v5.20.1
   FTL_BRANCH=master
   FTL_HASH=47128aaf
   GITHUB_FTL_VERSION=v5.20.1
   GITHUB_FTL_HASH=47128aaf
   DOCKER_VERSION=2023.01.10
   GITHUB_DOCKER_VERSION=2023.01.10
*** [ DIAGNOSING ]: contents of /etc/dnsmasq.d
-rw-r--r-- 1 root root 1.4K Jan 30 17:20 /etc/dnsmasq.d/01-pihole.conf
   addn-hosts=/etc/pihole/local.list
   addn-hosts=/etc/pihole/custom.list
   localise-queries
   no-resolv
   log-queries
   log-facility=/var/log/pihole/pihole.log
   log-async
   cache-size=10000
   server=8.8.8.8
   server=1.1.1.1
   domain-needed
   expand-hosts
   bogus-priv
   except-interface=nonexisting
-rw-r--r-- 1 root root 2.2K Jan 30 17:20 /etc/dnsmasq.d/06-rfc6761.conf
   server=/test/
   server=/localhost/
   server=/invalid/
   server=/bind/
   server=/onion/
*** [ DIAGNOSING ]: contents of /etc/lighttpd
-rw-r--r-- 1 root root 2.2K Jan 19  2022 /etc/lighttpd/lighttpd.conf
   server.modules = (
       "mod_indexfile",
       "mod_access",
       "mod_alias",
        "mod_redirect",
   server.document-root        = "/var/www/html"
   server.upload-dirs          = ( "/var/cache/lighttpd/uploads" )
   server.errorlog             = "/var/log/lighttpd/error.log"
   server.pid-file             = "/run/lighttpd.pid"
   server.username             = "www-data"
   server.groupname            = "www-data"
   server.port                 = 80
   server.feature-flags       += ("server.h2proto" => "enable")
   server.feature-flags       += ("server.h2c"     => "enable")
   server.feature-flags       += ("server.graceful-shutdown-timeout" => 5)
   server.http-parseopts = (
     "header-strict"           => "enable",# default
     "host-strict"             => "enable",# default
     "host-normalize"          => "enable",# default
     "url-normalize-unreserved"=> "enable",# recommended highly
     "url-normalize-required"  => "enable",# recommended
     "url-ctrls-reject"        => "enable",# recommended
     "url-path-2f-decode"      => "enable",# recommended highly (unless breaks app)
     "url-path-dotseg-remove"  => "enable",# recommended highly (unless breaks app)
   index-file.names            = ( "index.php", "index.html" )
   url.access-deny             = ( "~", ".inc" )
   static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
   include_shell "/usr/share/lighttpd/use-ipv6.pl " + server.port
   include_shell "/usr/share/lighttpd/create-mime.conf.pl"
   include "/etc/lighttpd/conf-enabled/*.conf"
   server.modules += (
       "mod_dirlisting",
       "mod_staticfile",
*** [ DIAGNOSING ]: contents of /etc/cron.d
-rw-r--r-- 1 root root 1.7K Jan 25 21:35 /etc/cron.d/pihole
   18 3   * * 7   root    PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole/pihole_updateGravity.log || cat /var/log/pihole/pihole_updateGravity.log
   00 00   * * *   root    PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
   @reboot root /usr/sbin/logrotate --state /var/lib/logrotate/pihole /etc/pihole/logrotate
   30 18  * * *   root    PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker
   @reboot root    PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker reboot
*** [ DIAGNOSING ]: contents of /var/log/lighttpd
-rw-r--r-- 1 www-data www-data 1.9K Jan 30 17:20 /var/log/lighttpd/error-pihole.log
   -----head of error-pihole.log------
   2023-01-29 22:36:57: server.c.1513) server started (lighttpd/1.4.59)
   2023-01-30 17:04:01: mod_fastcgi.c.487) FastCGI-stderr:pHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 947
   2023-01-30 17:04:32: mod_fastcgi.c.487) FastCGI-stderr:pHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 947
   2023-01-30 17:04:49: mod_fastcgi.c.487) FastCGI-stderr:pHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 947
   2023-01-30 17:05:13: mod_fastcgi.c.487) FastCGI-stderr:pHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 947
   2023-01-30 17:05:47: mod_fastcgi.c.487) FastCGI-stderr:pHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 947
   2023-01-30 17:06:13: mod_fastcgi.c.487) FastCGI-stderr:pHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 947
   2023-01-30 17:07:04: mod_fastcgi.c.487) FastCGI-stderr:pHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 947
   2023-01-30 17:20:17: server.c.1513) server started (lighttpd/1.4.59)
   2023-01-30 17:20:17: gw_backend.c.475) unlink /run/lighttpd/pihole-php-fastcgi.socket-0 after connect failed: Connection refused
   -----tail of error-pihole.log------
*** [ DIAGNOSING ]: contents of /var/log/pihole
-rw-r--r-- 1 pihole pihole 25K Jan 30 17:37 /var/log/pihole/FTL.log
   -----head of FTL.log------
   [2023-01-30 09:18:37.238 836M] Resizing "FTL-dns-cache" from 8192 to (768 * 16) == 12288 (/dev/shm: 757.8KB used, 67.1MB total, FTL uses 745.8KB)
   [2023-01-30 09:27:59.245 836M] Resizing "FTL-domains" from 12288 to (1024 * 24) == 24576 (/dev/shm: 761.9KB used, 67.1MB total, FTL uses 749.9KB)
   [2023-01-30 10:28:10.107 836M] Resizing "FTL-dns-cache" from 12288 to (1024 * 16) == 16384 (/dev/shm: 774.1KB used, 67.1MB total, FTL uses 762.2KB)
   [2023-01-30 14:06:19.099 836M] Resizing "FTL-dns-cache" from 16384 to (1280 * 16) == 20480 (/dev/shm: 778.2KB used, 67.1MB total, FTL uses 766.3KB)
   [2023-01-30 16:31:50.284 836M] Resizing "FTL-queries" from 229376 to (8192 * 56) == 458752 (/dev/shm: 782.3KB used, 67.1MB total, FTL uses 770.4KB)
   [2023-01-30 17:01:25.313 836M] Shutting down...
   [2023-01-30 17:01:25.580 836M] Finished final database update (stored 8 queries)
   [2023-01-30 17:01:25.580 836M] Waiting for threads to join
   [2023-01-30 17:01:25.580 836M] Thread database (0) is idle, terminating it.
   [2023-01-30 17:01:25.581 836M] Thread housekeeper (1) is idle, terminating it.
   [2023-01-30 17:01:25.581 836M] Thread DNS client (2) is idle, terminating it.
   [2023-01-30 17:01:25.581 836M] All threads joined
   [2023-01-30 17:01:25.581 836M] Joining API worker thread 0
   [2023-01-30 17:01:25.581 836M] Joining API worker thread 1
   [2023-01-30 17:01:25.581 836M] Joining API worker thread 2
   [2023-01-30 17:01:25.581 836M] Joining API worker thread 3
   [2023-01-30 17:01:25.581 836M] Joining API worker thread 4
   [2023-01-30 17:01:25.583 836M] ########## FTL terminated after 18h 22m 11s  (code 0)! ##########
   [2023-01-30 17:01:25.802 29727M] Using log file /var/log/pihole/FTL.log
   [2023-01-30 17:01:25.802 29727M] ########## FTL started on da099289320e! ##########
   [2023-01-30 17:01:25.803 29727M] FTL branch: master
   [2023-01-30 17:01:25.803 29727M] FTL version: v5.20.1
   [2023-01-30 17:01:25.803 29727M] FTL commit: 47128aaf
   [2023-01-30 17:01:25.803 29727M] FTL date: 2023-01-15 19:57:00 +0000
   [2023-01-30 17:01:25.803 29727M] FTL user: pihole
   [2023-01-30 17:01:25.803 29727M] Compiled for x86_64 (compiled on CI) using gcc (Debian 8.3.0-6) 8.3.0
   [2023-01-30 17:01:25.803 29727M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
   [2023-01-30 17:01:25.803 29727M]    SOCKET_LISTENING: only local
   [2023-01-30 17:01:25.803 29727M]    AAAA_QUERY_ANALYSIS: Show AAAA queries
   [2023-01-30 17:01:25.803 29727M]    MAXDBDAYS: max age for stored queries is 365 days
   [2023-01-30 17:01:25.803 29727M]    RESOLVE_IPV6: Resolve IPv6 addresses
   [2023-01-30 17:01:25.803 29727M]    RESOLVE_IPV4: Resolve IPv4 addresses
   [2023-01-30 17:01:25.803 29727M]    DBINTERVAL: saving to DB file every minute
   [2023-01-30 17:01:25.803 29727M]    DBFILE: Using /etc/pihole/pihole-FTL.db
   [2023-01-30 17:01:25.803 29727M]    MAXLOGAGE: Importing up to 24.0 hours of log data
   -----tail of FTL.log------
   [2023-01-30 17:20:18.192 232M] Database successfully initialized
   [2023-01-30 17:20:18.327 232M] New upstream server: 8.8.8.8:53 (0/512)
   [2023-01-30 17:20:18.394 232M] New upstream server: 1.1.1.1:53 (1/512)
   [2023-01-30 17:20:18.601 232M] Resizing "FTL-domains" from 12288 to (1024 * 24) == 24576 (/dev/shm: 753.7KB used, 67.1MB total, FTL uses 741.7KB)
   [2023-01-30 17:20:18.607 232M] Resizing "FTL-queries" from 229376 to (8192 * 56) == 458752 (/dev/shm: 766.0KB used, 67.1MB total, FTL uses 754.0KB)
   [2023-01-30 17:20:18.696 232M] Imported 4741 queries from the long-term database
   [2023-01-30 17:20:18.696 232M]  -> Total DNS queries: 4741
   [2023-01-30 17:20:18.696 232M]  -> Cached DNS queries: 815
   [2023-01-30 17:20:18.696 232M]  -> Forwarded DNS queries: 1968
   [2023-01-30 17:20:18.696 232M]  -> Blocked DNS queries: 1904
   [2023-01-30 17:20:18.696 232M]  -> Unknown DNS queries: 0
   [2023-01-30 17:20:18.697 232M]  -> Unique domains: 554
   [2023-01-30 17:20:18.697 232M]  -> Unique clients: 4
   [2023-01-30 17:20:18.697 232M]  -> Known forward destinations: 2
   [2023-01-30 17:20:18.697 232M] Successfully accessed setupVars.conf
   [2023-01-30 17:20:18.697 232M] listening on 0.0.0.0 port 53
   [2023-01-30 17:20:18.698 232M] listening on :: port 53
   [2023-01-30 17:20:18.699 232M] PID of FTL process: 232
   [2023-01-30 17:20:18.699 232M] Listening on port 4711 for incoming IPv4 telnet connections
   [2023-01-30 17:20:18.700 232M] Error binding to IPv6 telnet socket: Cannot assign requested address (99)
   [2023-01-30 17:20:18.700 232M] WARN: Cannot bind to IPv6 telnet socket
   [2023-01-30 17:20:18.700 232M] Listening on port 4711 for incoming socket telnet connections
   [2023-01-30 17:20:18.701 232M] INFO: FTL is running as user pihole (UID 999)
   [2023-01-30 17:20:18.701 232M] Reloading DNS cache
   [2023-01-30 17:20:18.802 232/T252] Compiled 0 whitelist and 0 blacklist regex filters for 4 clients in 0.4 msec
   [2023-01-30 17:20:18.803 232/T252] Blocking status is enabled
   [2023-01-30 17:22:06.943 232M] Received: Real-time signal 0 (34 -> 0)
   [2023-01-30 17:22:07.017 232/T252] Compiled 0 whitelist and 0 blacklist regex filters for 4 clients in 0.3 msec
   [2023-01-30 17:22:07.017 232/T252] Blocking status is enabled
   [2023-01-30 17:32:06.298 232M] Received: Real-time signal 0 (34 -> 0)
   [2023-01-30 17:32:06.342 232/T252] Compiled 0 whitelist and 0 blacklist regex filters for 4 clients in 0.3 msec
   [2023-01-30 17:32:06.342 232/T252] Blocking status is disabled
   [2023-01-30 17:37:06.269 232M] Received: Real-time signal 0 (34 -> 0)
   [2023-01-30 17:37:06.301 232/T252] Compiled 0 whitelist and 0 blacklist regex filters for 4 clients in 0.3 msec
   [2023-01-30 17:37:06.301 232/T252] Blocking status is enabled
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 84K Jan 30 17:20 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 248 Jan 30 17:20 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 4.0K Jan 30 17:20 /dev/shm/FTL-dns-cache
-rw------- 1 pihole pihole 24K Jan 30 17:20 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 88 Jan 30 17:20 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 8.0K Jan 30 17:20 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 4.0K Jan 30 17:20 /dev/shm/FTL-per-client-regex
-rw------- 1 pihole pihole 448K Jan 30 17:41 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 16 Jan 30 17:20 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 80K Jan 30 17:20 /dev/shm/FTL-strings
-rw------- 1 pihole pihole 308K Jan 30 17:20 /dev/shm/FTL-upstreams
-rw-r--r-- 1 root root 37 Jan 30 17:20 /etc/dnsmasq.conf
   conf-dir=/etc/dnsmasq.d
   user=pihole
-rw-r--r-- 1 root root 38 Jan 30 17:20 /etc/resolv.conf
   options ndots:0
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
*** [ DIAGNOSING ]: Locale
    LANG=
*** [ DIAGNOSING ]: Pi-hole log
-rw-r--r-- 1 pihole pihole 1.6M Jan 30 17:42 /var/log/pihole/pihole.log
   -----head of pihole.log------
   Jan 30 00:00:10 dnsmasq[836]: query[PTR] 8.8.8.8.in-addr.arpa from 127.0.0.1
   Jan 30 00:00:10 dnsmasq[836]: cached 8.8.8.8 is dns.google
   Jan 30 00:00:10 dnsmasq[836]: query[PTR] 1.1.1.1.in-addr.arpa from 127.0.0.1
   Jan 30 00:00:10 dnsmasq[836]: forwarded 1.1.1.1.in-addr.arpa to 1.1.1.1
   Jan 30 00:00:10 dnsmasq[836]: reply 1.1.1.1 is one.one.one.one
   Jan 30 00:00:12 dnsmasq[836]: query[A] push.prod.netflix.com from 192.168.0.14
   Jan 30 00:00:12 dnsmasq[836]: cached push.prod.netflix.com is <CNAME>
   Jan 30 00:00:12 dnsmasq[836]: forwarded push.prod.netflix.com to 1.1.1.1
   Jan 30 00:00:12 dnsmasq[836]: reply push.prod.netflix.com is <CNAME>
   Jan 30 00:00:12 dnsmasq[836]: reply push.prod.dradis.netflix.com is <CNAME>
   Jan 30 00:00:12 dnsmasq[836]: reply push.prod.eu-west-1.internal.dradis.netflix.com is <CNAME>
   Jan 30 00:00:12 dnsmasq[836]: reply pushy-prod-nlb4-888783e50761c9f4.elb.eu-west-1.amazonaws.com is 54.171.156.218
   Jan 30 00:00:12 dnsmasq[836]: reply pushy-prod-nlb4-888783e50761c9f4.elb.eu-west-1.amazonaws.com is 52.51.253.173
   Jan 30 00:00:12 dnsmasq[836]: reply pushy-prod-nlb4-888783e50761c9f4.elb.eu-west-1.amazonaws.com is 63.33.228.172
   Jan 30 00:00:27 dnsmasq[836]: query[A] nrdp.prod.cloud.netflix.com from 192.168.0.14
   Jan 30 00:00:27 dnsmasq[836]: cached nrdp.prod.cloud.netflix.com is <CNAME>
   Jan 30 00:00:27 dnsmasq[836]: forwarded nrdp.prod.cloud.netflix.com to 1.1.1.1
   Jan 30 00:00:27 dnsmasq[836]: reply nrdp.prod.cloud.netflix.com is <CNAME>
   Jan 30 00:00:27 dnsmasq[836]: reply nrdp.prod.dradis.netflix.com is <CNAME>
   Jan 30 00:00:27 dnsmasq[836]: reply nrdp.prod.eu-west-1.internal.dradis.netflix.com is <CNAME>
   -----tail of pihole.log------
   Jan 30 17:42:31 dnsmasq[232]: query[A] clientredirect-activemarketingpriv.dii1.ns-promovisionnet.net.zooplus.it from 192.168.0.222
   Jan 30 17:42:31 dnsmasq[232]: gravity blocked clientredirect-activemarketingpriv.dii1.ns-promovisionnet.net.zooplus.it is 0.0.0.0
   Jan 30 17:42:35 dnsmasq[232]: query[A] ms.applovin.com from 192.168.0.41
   Jan 30 17:42:35 dnsmasq[232]: gravity blocked ms.applovin.com is 0.0.0.0
   Jan 30 17:42:37 dnsmasq[232]: query[A] ms.applvn.com from 192.168.0.41
   Jan 30 17:42:37 dnsmasq[232]: gravity blocked ms.applvn.com is 0.0.0.0
   Jan 30 17:42:37 dnsmasq[232]: query[A] appsrv.display.io from 192.168.0.41
   Jan 30 17:42:37 dnsmasq[232]: gravity blocked appsrv.display.io is 0.0.0.0
   Jan 30 17:42:40 dnsmasq[232]: query[A] ms.applovin.com from 192.168.0.41
   Jan 30 17:42:40 dnsmasq[232]: gravity blocked ms.applovin.com is 0.0.0.0
   Jan 30 17:42:40 dnsmasq[232]: query[A] appsrv.display.io from 192.168.0.41
   Jan 30 17:42:40 dnsmasq[232]: gravity blocked appsrv.display.io is 0.0.0.0
   Jan 30 17:42:42 dnsmasq[232]: query[A] ms.applvn.com from 192.168.0.41
   Jan 30 17:42:42 dnsmasq[232]: gravity blocked ms.applvn.com is 0.0.0.0
   Jan 30 17:42:44 dnsmasq[232]: query[A] ms.applovin.com from 192.168.0.41
   Jan 30 17:42:44 dnsmasq[232]: gravity blocked ms.applovin.com is 0.0.0.0
   Jan 30 17:42:47 dnsmasq[232]: query[A] ms.applvn.com from 192.168.0.41
   Jan 30 17:42:47 dnsmasq[232]: gravity blocked ms.applvn.com is 0.0.0.0
   Jan 30 17:42:51 dnsmasq[232]: query[A] ms.applovin.com from 192.168.0.41
   Jan 30 17:42:51 dnsmasq[232]: gravity blocked ms.applovin.com is 0.0.0.0
[✓] ** FINISHED DEBUGGING! **
   * The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
   * A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
E no to znaczy że coś blokuje.
dodaj do listy blokowanych wp.pl (bo to i tak rak) i sprawdź czy możesz wejść na główną stronę.
Co do blokowania reklam na YT - u mnie samo pihole nie dawało rady albo były problemy żeby cokolwiek obejrzeć albo nie blokowało reklam.
Na kompie mam kombo pihole + ublock + youtube enchancer + sponsor block i reklam nie ma
na TV pihole + SmartTube
na telefonie nie korzystam z YT (rak + metr mułu)
PiHole to u mnie domyślny DNS dla wszystkiego w sieci nawet IoT.
@EDIT:
Próbujesz dodać to w sieci bridge czyli na adresie QNAP-a - to nie działa bo QNAP okupuje port 53 (dns)
@EDIT2:
Jak pisałem na początku nic na QNAPie nie jest proste :p
Kup RaspberryPi 4b postaw tam debiana i na tym PiHole 110% mniej problemów niż z Qnapem
@EDIT:
Co do blokowania to on faktycznie ruch widzi, zlicza coś ale niestety nawet 1 reklamy nie usunie..
  1. pihole
  2. adguard
  3. *
  4. netflix
  5. pi hole
  6. container sieć
  7. reject md5 servers = yes
  8. pihole docker-compose
  9. container settings
  10. samsung evo 970
  11. docker proc
  12. pihole konfiguracja
  13. Listy do pihole
  14. pi-hole
  15. docker status
  16. localhost docker
  17. cont
  18. active directory
  19. filtry
  20. ls proc
  21. pihole docker
  22. pihole listy
  23. ubuntu station
  24. dns domain forward
  25. drukarka
  26. qnet
  27. switch do 10 gbe
