krystianen
System Engineer
Q Specialist
25 Styczeń 2010
102
135
Poznań
Wersja oprogramowania Firmware: 4.4.1 Build 20YYMMDD
Model serwera: QNAP TS-251A
Zainstalowałem PI HOLE na dockerze jednak podczas uruchomienia mam bład
Czy ktoś się spotkał z takim problemem?
[✗] DNS resolution is currently unavailable
Doszukałem się że musze ze musze zedytować DNSy w pliku /etc/resolf.conf tylko nie wiem jak sie mam do niego stać. Bo wyrzuceniu w/w błedy pi hole sie wylacza.
 ::: Starting docker specific checks & setup for docker pihole/pihole
WARNING Misconfigured DNS in /etc/resolv.conf: Two DNS servers are recommended, 127.0.0.1 and any backup server
WARNING Misconfigured DNS in /etc/resolv.conf: Primary DNS should be 127.0.0.1 (found 127.0.0.11)
nameserver 127.0.0.11
options ndots:0
Assigning random password: -6wj8quc
  [i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u5
  [i] Installing configs from /etc/.pihole...
  [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone!
  [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Setting password: -6wj8quc
+ pihole -a -p -6wj8quc -6wj8quc
  [✓] New password set
Using default DNS servers: 8.8.8.8 & 8.8.4.4
DNSMasq binding to default interface: eth0
Added ENV to php:
                        "PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
                        "ServerIP" => "0.0.0.0",
                        "VIRTUAL_HOST" => "0.0.0.0",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
https://mirror1.malwaredomains.com/files/justdomains
http://sysctl.org/cameleon/hosts
https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
https://hosts-file.net/ad_servers.txt
::: Testing pihole-FTL DNS: FTL started!
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
::: Docker start setup complete
  [i] Pi-hole blocking is enabled
  [✗] DNS resolution is not available
[cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
kontener ma być odpalony z siecią w trybie BRIDGE (nazwa sterownika) - więc współdzieli zajęte porty z swoim hostem (więc QNAPem), jeśli port 67 jest zajęty , to kontener nie może używać portu 67
rozwiązaniem jest przełączenie sieci tego kontenera do innego sterownika (Networking overview), ale to wykracza poza moją wiedzę
niech ktoś ci z tym pomoże
pomocne może być Wiedza - docker-compose
niestety dalej nie pomogę bo nie mam QNAPa, a Silas Mariusz Silas Mariusz nie raczył załatwić mi licencji na QNAP w chmurze :(
Ja to mam odpalone na RPi4, ogarnia na stałe ok. 28 klientów ale na QNAPie nic nie jest takie proste ;)
Wszystko wykonujesz przez FAQ SSH z konta ADMIN (tak musi być admin - jeśli dałeś się nabrać na QNAPowy żart o wyłączeniu tego użytkownika to teraz go włącz).
FAQ - Jak połączyć się po SSH do Linux w serwerze QNAP (PuTTY Windows)
Wszystko zostało przetestowane na QNAP TS-453Be (procesor x86-64, QTS 5.0.1.x) - jeśli masz inny model, wersje QTS a w szczególności procesor mogą pojawić się dodatkowe kroki do wykonania nie przewidziane w tej instrukcji. Instrukcja zakłada również że posiadasz minimalną wiedzę na temat Linuksa, dockera oraz potrafisz czytać ze zrozumieniem.
Na początek wykonujesz poniższe polecenia - tworzą katalog dla docker-compose i pliki do startu / aktualizacji kontenera.
Zamień /share/Public na dowolny inny katalog na dysku (coś z /share/) lub zostaw jak jest.
cd /share/Public
mkdir pihole
cd pihole
touch docker-compose.yml
touch run.sh
touch upgrade.sh
chmod +x run.sh
chmod +x upgrade.sh
Jeśli nie masz zdefiniowanej sieci ze statycznymi adresami IP dla dockera to można ją stworzyć tym poleceniem - kontener wykorzystuje taką siec i warto mieć stałe IP dla serwera DNS.
docker network create \
-d qnet \
--ipam-driver=qnet \
--ipam-opt=iface=qvs0 \
--subnet=10.11.12.0/24 \
--gateway=10.11.12.51 \
qnet-static
Zamienić qvs0 na swój własny interfejs wykonać polecenie ifconfig i znaleźć nazwę interfejsu który ma ten sam adres co QNAP
Zamienić subnet=10.11.12.0/24 na swoją własną podsieć
Zamienić gateway=10.11.12.51 na swoją bramę domyślną (router czy co tam masz)
Teraz trzeba dodać zawartość stworzonych plików oraz podmienić w nich kilka wartości na własne. Używam woluminów bo są mniej problematyczne w niektórych konfiguracjach (Wiedza - PiHole - QNAP )
docker-compose.yml
Sekcja enviroment:
WEBPASSWORD: na swoje własne hasło do panelu admina
ADMIN_MAIL: na swój adres email
Sekcja networks:
ipv4_address: na wolny statyczny adres IP w twojej sieci
Sekcja deploy:
cpus: można dopasować ile CPU ma otrzymywać (wartość między 0.1 a 2.0 będzie wystarczajaca - w razie potrzeby zmniejszać / zwiększać)
memory: można dopasować ilość RAM - dla bardzo dużej ilości klientów można zwiększyć
YAML:
version: '3.8'
services:
  pihole:
    container_name: pihole
    environment:
      PIHOLE_UID: 0
      PIHOLE_GID: 100
      TZ: 'Europe/Warsaw'
      WEBPASSWORD: 'SuperTajneHasłoKtoregoNiktNiezgadnie3'
      ADMIN_EMAIL: 'super@admin.net'
      IPv6: false
    hostname: pi.hole
    image: pihole/pihole:latest
    networks:
      qnet-static:
        ipv4_address: 10.11.12.6
    ports:
      - 53:53/tcp
      - 53:53/udp
      - 67:67/udp
      - 80:80/tcp
    restart: always
    volumes:
      - 'data:/etc/pihole/'
      - 'dnsmasq:/etc/dnsmasq.d'
    deploy:
      resources:
        limits:
          cpus: '2.0'
          memory: 512M
networks:
  qnet-static:
    external: true
volumes:
    data:
    dnsmasq:
run.sh
#!/bin/bash
docker-compose up -d --force-recreate
upgrade.sh
#!/bin/bash
docker-compose pull
docker-compose rm -s -f
docker-compose up -d --force-recreate --remove-orphans
docker image prune -f
Kiedy wszystko jest gotowe można uruchomić kontener poleceniem ./run.sh
Aby zaktualizować kontener, wystarczy odpalić ./upgrade.sh
Listy których używam:
https://hole.cert.pl/domains/domains_hosts.txt
https://raw.githubusercontent.com/M...ter/master/polish-pihole-filters/hostfile.txt
https://raw.githubusercontent.com/M...aster/polish-pihole-filters/easylist_host.txt
https://raw.githubusercontent.com/M...r/polish-pihole-filters/easy_privacy_host.txt
https://raw.githubusercontent.com/M...master/polish-pihole-filters/adguard_host.txt
https://raw.githubusercontent.com/M...ter/master/polish-pihole-filters/kad_host.txt
https://raw.githubusercontent.com/hoshsadiq/adblock-nocoin-list/master/hosts.txt
https://raw.githubusercontent.com/M...hole-filters/Ad_filter_list_by_Disconnect.txt
https://raw.githubusercontent.com/M...polish-pihole-filters/adguard_crypto_host.txt
https://raw.githubusercontent.com/M...polish-pihole-filters/adguard_mobile_host.txt
https://raw.githubusercontent.com/M...er/master/polish-pihole-filters/adservers.txt
https://raw.githubusercontent.com/M...ster/polish-pihole-filters/gambling-hosts.txt
https://raw.githubusercontent.com/M.../master/polish-pihole-filters/SmartTV_ads.txt
https://raw.githubusercontent.com/kevinle-1/Windows-telemetry-blocklist/master/windowsblock.txt
https://raw.githubusercontent.com/kboghdady/youTube_ads_4_pi-hole/master/youtubelist.txt
https://adaway.org/hosts.txt
https://v.firebog.net/hosts/AdguardDNS.txt
https://v.firebog.net/hosts/Admiral.txt
https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt
https://v.firebog.net/hosts/Easylist.txt
https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/UncheckyAds/hosts
https://raw.githubusercontent.com/bigdargon/hostsVN/master/hosts
https://raw.githubusercontent.com/PolishFiltersTeam/KADhosts/master/KADhosts.txt
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.Spam/hosts
https://v.firebog.net/hosts/static/w3kbl.txt
https://v.firebog.net/hosts/Easyprivacy.txt
https://v.firebog.net/hosts/Prigent-Ads.txt
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.2o7Net/hosts
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/spy.txt
https://hostfiles.frogeye.fr/firstparty-trackers-hosts.txt
https://raw.githubusercontent.com/DandelionSprout/adfilt/master/Alternate versions Anti-Malware List/AntiMalwareHosts.txt
https://osint.digitalside.it/Threat-Intel/lists/latestdomains.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt
https://v.firebog.net/hosts/Prigent-Crypto.txt
https://bitbucket.org/ethanr/dns-bl...bad_lists/Mandiant_APT1_Report_Appendix_D.txt
https://phishing.army/download/phishing_army_blocklist_extended.txt
https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-malware.txt
https://raw.githubusercontent.com/Spam404/lists/master/main-blacklist.txt
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.Risk/hosts
https://urlhaus.abuse.ch/downloads/hostfile/
https://zerodot1.gitlab.io/CoinBlockerLists/hosts_browser
https://raw.githubusercontent.com/hagezi/dns-blocklists/main/domains/multi.txt
tak mam
upgrade.sh poszlo bez problemu ale widzę error który muszę się zająć bo wcześniej virtual switch zrobiłem i musze go chyba tam wstawić
No stopped containers
ERROR: Network qnet-static declared as external, but could not be found. Please create the network manually using `docker network create qnet-static` and try again.
-d qnet \
qnet-static
tak wiem, że ten krok muszę zrobić ale nadal przez FAQ SSH coś mi nie chce
wybaczcie za mój nie ogar ale staram się :) jest jakiś postęp
co nie zmienia faktu docker network nie działa...
Co Ci wyświetla:
which docker
nie musisz zmienić powłoki (sh/bash) tu to nie ma sensu ale brak widocznej komendy docker może świadczyć o tym że nie masz uruchomione aplikacji "Container Station"
Mimo wszystko nie wiem czy nie jest wymagane "sudo" do zarządzania dockerem ale to inni się wypowiedzą możne.
  1. pihole
  2. adguard
  3. *
  4. netflix
  5. pi hole
  6. container sieć
  7. reject md5 servers = yes
  8. pihole docker-compose
  9. container settings
  10. samsung evo 970
  11. docker proc
  12. pihole konfiguracja
  13. Listy do pihole
  14. pi-hole
  15. docker status
  16. localhost docker
  17. cont
  18. active directory
  19. filtry
  20. ls proc
  21. pihole docker
  22. pihole listy
  23. ubuntu station
  24. dns domain forward
  25. drukarka
  26. qnet
  27. switch do 10 gbe
